    Load and write blocks of 512 direct to sd card M5Core2
    Units
    m5stack fire m5core2
    5.2k
    • P
      Powersoft
      Is it possible to read/write blocks of 512 bytes direct to the sd card?
      This without using the M5Stack filesystem.
      I know with the SDFat.h library it is possible, there are commands for readBlock(block,buffer) and writeBlock(block, buffer), and buffer is defined as
      byte buffer[512].
      But I get not compiled this library under my Core2.
      Appreciatie any help with this.
      Cheers,
      Jan
