    CORE2, LAN Module W5500 with POE and RS-485
    Core 2
    4.6k
    • H
      hbenkel
      The RS-485 board of the LAN Module W5500 with POE works fine only
      if the PORT.A.I2C of the CORE2 is not used. If the external I2C port
      is in use the RS-485 communication looses the RX signal, because
      of the G33 asignation for both purposes, RX and PA_SCL.
      Somebody knows how to fix this?
      Thanks!
        Hello @hbenkel
        the only way I see is to rewire RX to an unused GPIO. Maybe this GPIO overview I've put together a while back will help you.
        • H
          hbenkel @felmue
          @felmue Thanks Felix for the reply. I wired the pin 27 for RX and now both RS-485 and I2C works fine.
          Regards
            Hello @hbenkel
            you are welcome. I am glad to hear you got it working to your liking.
            Happy Stacking!
