    m5stack unitv2 AI Camera - getting started
    11 Posts 6 Posters 19.4k Views 3 Watching
      patmolloy
      Just arrived. When I plug into a Windows 10 machine I see a device called USB 10/100 LAN with the yellow warning triangle. So no driver. Where do I find the driver, please?
      Also, by default should I be able to access the device via WiFI on the SSID M5UV2_XXXX ? I see no such SSID being broadcast.
      Thanks!
      Pat
      • m5stackM Offline
        check the tutorial you will get the driver
        https://docs.m5stack.com/en/quick_start/unitv2/base_functions
        • nechryN Offline
          nechry
          same issue for me, the device didn’t broadcast any WiFi. I can only connect via the USB ethernet Lan.
          Also, Is there a way to use the USB network adapter on OSX system?
          • itsover9000I Offline
            itsover9000
            Same issue, im running a mac so i think hotspot connectivity is my only choice and im having same issue the wifi network is not available to connect ?
            • nechryN Offline
              nechry
              I can’t see the ssid from my side. anything to active on the unit?
              any chance to get the driver for macOSX?
                itsover9000
                Maybe for Mac os this is the driver http://www.corechip-sz.com/endownload.asp
                "SR9900 MacOS Big Sur Driver"
                Its not available to download for normal user.
                Thanks. Alex
                  albert8413
                  Hi allk. Same for me no Ap is broadcasted. Can ssh to the unit via 10/100 USB-LAN, but sudo is not working so even when finding the configuration for WLAN I think its not possible to change.
                  • m5stackM Offline
                    we debug these issues now. we will release the new firmware update to fix it later.
                    nechryN 1 Reply Last reply Reply Quote -1
                    • nechryN Offline
                      nechry @m5stack
                      @m5stack ok thank for the update. do you have a expected release date for the next firmware with wifi?
                      • m5stackM Offline
                        m5stack @nechry
                        @nechry not yet. sorry. when we update it , we will public a post to the community.
                        • AsmodevA Offline
                          Asmodev
                          Having a similar issue, I've got into the web server, but the AP isn't starting, I can't even find the AP ID or even tell if it's started?
