šŸ¤–Have you ever tried Chat.M5Stack.com before asking??šŸ˜Ž
    GPS Module. M5Stack Gray
    2 Posts 2 Posters 2.8k Views
      aeroagri.dev
      Ola possuo um modulo de GPS, porem para minha aplicação necessito converter o dado recebido pelo modo em um numero INT ou FLOAT, porem ao tentar utilizar a conversão o sistema relata um erro. Alguém possui uma solução para este problema de conversão?
      Brazil
      Hello I have a GPS module, however for my application I need to convert the data given by the mode into an INT or FLOAT number, however I try a conversion in the system the same reports an error. Does anyone have a solution to this conversion problem?
      • m5stackM Offline
        ah. that seems like a program grammar issues. you need confirm the str don't included any "Special characters". before you use function to conversion it
        With your input, this post could be even better šŸ’—
