    UnitV2 Linux Firmware?
    FAQS
    9.6k
    • AsmodevA
      Asmodev
      I've modified the network stack and lost access to the device through usb/wifi, what can i use to reflash the device?
      • AsmodevA
        Asmodev
        • AsmodevA
          Asmodev
          • AsmodevA
            Asmodev
            Nvm, i fixed it by altering the firmware file deploy.py using 7zip and notepad++ and adding this text to the deploy file just above "dnsmasq_file = "
            Please note the backslash at the end of dhcpcd_file=here is missing (forum problem_
            FIX BEGINS HERE - COPY BELLOW THIS LINE
            dhcpcd_file =
            nohook lookup-hostname
            interface eth0
            static ip_address=10.254.239.1/24
            static routers=10.254.239.1
            open('/etc/dhcpcd.conf', 'w+').write(dhcpcd_file)
            FIX ENDS HERE
            It restored the network on the UnitV2
            • A
              AMINEKH
              I am in the same situation, I ask for more details thank you in advance
