    REMOTE+ Slider for motors
    11 Posts 4 Posters 19.3k Views 1 Watching
    • W Offline
      Werner_G
      I like the REMOTE+ - feature. Works fine, but... The slider range starts at 0 and ends with 100. Most motors are controlled in the range of -127 to +127. Has anyone an idea of how to manage this?
        you need to use the map block to map the range
        • W Offline
          Werner_G
          you are probably right. But I cannot see any similarity with the maps-function of other IDE's. Great would be a mathematical function like this from MakeCode:
          "map 'speed' from low '0' high '100' to low '-127' high '127'" (or vice versa)
          Using arrays is very compicated, too much for me.
            robalstona
            def translate(value, inMin, inMax, outMin, outMax):
                return (value - inMin) * (outMax - outMin) / (inMax - inMin) + outMin
            • W Offline
              Werner_G
              Thank you. I tried this:
              def slider_Motor_callback(slider_value):
              global inMin, inMax, outMin, outMax, tof_0
              motion = Motion()
              inMin = 0
              inMax = 100
              outMin = -127
              outMax = 127
              def translate(slider_value, inMin, inMax, outMin, outMax):
              return (slider_value - inMin) * (outMax - outMin) / (inMax - inMin) + outMin
              motion.set_motor_speed(1, slider_value)
              But this doesn't work. What might be wrong?
                joueurgear
                the definition of your function has been created but you have to call it now with :
                • W Offline
                  Werner_G
                  I also tried this - but with no success. Seems that mapping or translating might not work in combination with REMOTE. Thanks for your help!
                    robalstona
                    Try this:
                      motion = Motion()
                      motion.set_motor_speed(1, translate(slider_value, 0, 100, -127, 127) )
                    • W Offline
                      Werner_G @robalstona
                      @robalstona
                      with this definition the motors shows absolutely no movement.
                        robalstona
                        @Werner_G, probably there is a problem with remote control. In this thread is a post about it
                        https://community.m5stack.com/topic/3477/uiflow-1-8-1
                        • W Offline
                          Werner_G
                          Finally, I've got it working using the map-block from Easy I/O in UIFlow (by chance I found it!), which is just
                          motion.set_motor_speed(2, map_value(slider_value, 0, 100, -127, 127))
                          without any translation. Works fine with Remote+
