    I'm unable to send data to AWS IoT
    9 Posts 3 Posters 11.5k Views 1 Watching
      Marsora
      Hi all,
      I'm using UIFLOW to send data to AWS IoT (attached the connection diagram).
      In the AWS IoT Monitor I see successful connection data, so the device connects but I don't see any published values in the test.
      Can anyone help me?
      Thank you
      Mario
      • IAMLIUBOI Offline
        IAMLIUBO
        Hi @Marsora ,
        Did you setting the policy? Such as the publish rules.
          Have you followed all the guide word for word filling in the policy, incognito and correct server?
          It can be a real pain to get connected but it does work eventually.
            Marsora @IAMLIUBO
            @iamliubo said in I'm unable to send data to AWS IoT:
            Hi @Marsora ,
            Hi @IAMLIUBO,
            yes i set the following policy, do you see any errors?
            But I haven't written any rules, is that the problem?
            (I have created only the thing, the certificate and the policy)
              Marsora @ajb2k3
              @ajb2k3 said in I'm unable to send data to AWS IoT:
              Hi @ajb2k3,
              I followed this guide, is it correct?
                ajb2k3 @Marsora
                @marsora said in I'm unable to send data to AWS IoT:
                Hi @ajb2k3,
                @IAMLIUBO the instructions on your site don't work as they are missing some steps.
                @Marsora you need to set aa "Cognito" profile in AWS.
                Rashibs guide on the RPI its for the RPI but works for the M5Stack.
                  Marsora @ajb2k3
                  @ajb2k3 I tried but it doesn't work, maybe I'm doing something wrong.
                  Is there a guide with all the steps?
                    Did you try Rashibs guide?
                      Marsora @ajb2k3
                      Yes, but it doesn't work.
                      I tried with the AWS Python SDK and it works.
