    pneumatic seeder
    PROJECTS
    9.3k
    • F
      fameuhly
      i've just discovered M5stack, great product !
      I am a farmer and I produce organic vegetables.
      I have a project of pneumatic seed drill with venturi effect.
      I know a little arduino but not at all micropython.
      I am a little lost, I would like to know where to start my project.
      I have to control stepper motors and a solenoid valve.
      I would like to start simply by programming a stepper motor to advance a conveyor belt.
      Any ideas to help me?
      thank you very much
      • J
        Julian
        There is an Arduino IDE stepper motor example listed on the M5stack site - I think it links to this forum. It is very simplistic, controlling a stepper to make a simple "clock" but it should be enough to get you started.
        • F
          fameuhly
          Hello, thank you Julian, i've tried this sample. It work fine.
          But is there a sample of this code with comments too really understand each part ?
          Is there some exemples with "fritzing" draw ?
          thank you.
          • F
            fameuhly
            Hello again,
            i've made a sketch on arduino ide to control a nema 17 stepper motor with the shield L298N
            here is the sketch :
            Controle de moteur pas à pas avec un L298N
            Le moteur est connecté sur les broches 2,3,4 et 5 de l'Arduino
            Le fil de masse (GND) est commun aux 2 platines.
            #include <Stepper.h>
            const int NbPasParTour = 200; // Nombre de pas pour 360 degres
            Stepper Moteur1(NbPasParTour, 2, 3, 4, 5); // Initialise le moteur sur les broches 2 à 5
            void setup()
            Moteur1.setSpeed(60); //Vitesse de rotation du moteur
            Serial.begin(9600); //Initialise le moniteur série
            void loop()
            Serial.println("Sens horaire"); //On fait 1 tour en sens horaire
            Moteur1.step(NbPasParTour);
            delay(1000); //Pause 1 seconde
            Serial.println("Sens anti-horaire"); //On fait 1 tour en sens anti-horaire
            Moteur1.step(-NbPasParTour);
            It's work fine !
            But when i try on the m5, on the PIN 3, 1, 16, 17 with this sketch, the motor only vibrate :
            Le moteur est connecté sur les broches 3, 1, 16, 17 du m5
            #include <M5Stack.h>
            Stepper Moteur1(NbPasParTour, 3, 1, 16, 17); // Initialise le moteur sur les broches
            void setup()
            Moteur1.setSpeed(100); //Vitesse de rotation du moteur
            m5.begin();
            M5.Lcd.setBrightness(200);
            M5.Lcd.setTextColor(0xffff);
            M5.Lcd.setTextSize(3);
            M5.Lcd.setCursor(50, 20);
            M5.Lcd.print("M5 Seeder");
            void loop()
            M5.Lcd.setTextColor(0x7bef);
            M5.Lcd.setTextSize(2);
            M5.Lcd.setCursor(55, 60);
            M5.Lcd.print("Sens horaire");
            Moteur1.step(NbPasParTour*2);
            M5.Lcd.print("Sens anti-horaire");
            m5.update();
            Any idea ?
            thank you
