    M5stickC turn on when connect Type-C USB with power (How to disable?)
    4 Posts 3 Posters 6.1k Views
      sgnp2091
      When I plugin Type-C USB with power, M5stickC will turn on automatically. Is it possible to disable?
        Hello @sgnp2091
        do you mean disable by software or hardware?
        The way M5StickC Plus is wired internally I don't think it is possible to disable this functionality by software, but I guess it would be possible by a hardware modification.
          sgnp2091 @felmue
          I would like to disable this function by Arduino. I don't want to modify the hardware. Btw, thank you for your reply.
          • E Offline
            edoceder
            Don't know if still relevant, but you can just power it off if you see it was plugged in.
            I attach a basic code here, and you can tweak it to your needs of course.
            Be aware that you might need to use a small delay before M5.Axp.GetVBusVoltage() will give you a result you can trust.
            //function which reads the voltage coming out of the USB, and if it's above 4.1 I know the device is being charged.
            bool isBeingCharged()
            float charge = M5.Axp.GetVBusVoltage();
            //Serial.println(charge);
            return charge > 4.1;
            //check here of anywhere you want in the code if the device is being charged, and power it off.
            void setup()
            if (isBeingCharged())
            M5.Axp.PowerOff();
