    UIFlow - Trimming Strings
    Scheduled Pinned Locked Moved Features Wish List
    12 Posts 3 Posters 21.5k Views 1 Watching
    • N Offline
      notdodgy
      I had an issue with processing json data that would not parse because it had a [ at the start and a ] at the the end.
      There is no easy way to remove these characters.
      There is a trim spaces block.
      What would be good would be a version of this block that trims ANY characters from the ends of a string. It would also act as a substr option.
      My clunky work around was:
      • Replace all spaces with a couple of ££ characters.
      • Replace all the [ with spaces.
      • Use the trim spaces block
      • Replace all spaces with [
      • Replace all the ] with spaces.
      • Replace all spaces with ]
      • Replace all the ££s with a space.
      Working out what the problem was took a while, but it took longer to find a way to make it work.
      • IAMLIUBOI Offline
        IAMLIUBO
        Hi @notdodgy ,
        We will add this block:
          robalstona
          @notdodgy there is also replace block. It has a three arguments:
          first is text to replace in your case [
          second is a replacing text, in your case leave blank.
          and third is your text or variable containing it.
          • N Offline
            notdodgy
            That is good to hear.
            I started looking at a custom block but could find the right Python command.
            string[n:n] does not work.
            • N Offline
              notdodgy @robalstona
              @robalstona said in UIFlow - Trimming Strings:
              That is what I used but to only remove the first and last characters takes a number of search and replaces.
                robalstona
                @notdodgy, show me example input string, and write what exactly you need "extract" from this json string. Show me what string you except as output according to example input string. It is a some kind of homework?. I don't know why you make so many character substitutions in the text.
                in python code you could use this construction:
                out_str = in_str.replace('[', '').replace(']', '').replace...
                but i dont tested yet how long may be replace chain.
                • N Offline
                  Hello. It's a simple problem but the work around is not.
                  This is a fairly large chunk of data which is json encoded.
                  It's provided from a server API which I cannot change.
                  It's from the servers that control my Car home charger.
                  I am creating a remote monitor as a simple visual display. I can also use it to do basic start/stop actions.
                  It contains a number of [ and ] and spaces in the body which I need to keep unchanged.
                  My simple problem is it has an additional "[" at the start and a "]" at the end.
                  This extra pair of [ and ] stop "loads json" from working.
                  I only need to lose the first and last characters of the received data, while keeping the rest unchanged.
                  In other programming languages it would be a substr(data,1,(strlen(data)-2)) or string[1:-1] .
                    robalstona @notdodgy
                    @notdodgy
                    In python this also works
                    out_str = in_str[1:-1]
                    • N Offline
                      notdodgy
                      I had tried that in a custom block but it didn't work.
                      Thanks for confirming the syntax.
                      I spotted that I had misread the custom block syntax rules and had included extra quotes.
                      I now have a working custom block that simply removes the first and last characters.
                      I have an input called Trimmer
                      The code section has ${Trimmer}[1:-1]
                        robalstona
                        Try change name of function or variable. At now they had the same names.
                        Maybe this construction will be work
                        str(${Trimmer})[1:-1]
                        • N Offline
                          @robalstona Thanks for your suggestion.
                          The Custom block builder creates the code and the code used in block shown above does work.
                          I opted to have the block and the name of the variable the same.
                          The variable name appears on the block so effectively names the block.
                          (If you don't have a variable as input, you can use a label, having both looked confusing and doubled the height of the block ).
                          • N Offline
                            notdodgy
                            @iamliubo said in UIFlow - Trimming Strings:
                            Hi @notdodgy ,
                            Hello -
                            Tried this new trim version and it works fine.
                            Guessed correctly that I needed to use "[ ]" as the trim characters in the first part.
                            No need for me to use a custom trim function.
