    "get Battery Level" issue
    Bug Report
    6.0k
    • R
      rbarsa
      Hi, I am using the 24bit HX711 connected on port A to measure the weight from sensor. All works, but when call the "get Battery level" , the measurement show nonsense number and stop working. Any idea ?
      Device: M5Stack core
      firmware: v1.8.3 (via M5Burner)
      UIFlow: v1.8.3
      • IAMLIUBOI
        IAMLIUBO @rbarsa
        Hi @rbarsa ,
        Could you paste your block code picture?
        • R
          rbarsa
          from m5stack import *
          from m5ui import *
          from uiflow import *
          import unit
          setScreenColor(0x222222)
          weigh_1 = unit.get(unit.WEIGHT, unit.PORTA)
          proc = M5TextBox(90, 46, "proc", lcd.FONT_DejaVu40, 0xFFFFFF, rotate=0)
          gram = M5TextBox(128, 125, "gram", lcd.FONT_DejaVu40, 0xFFFFFF, rotate=0)
          label2 = M5TextBox(0, 46, "Bat:", lcd.FONT_DejaVu40, 0xFFFFFF, rotate=0)
          label3 = M5TextBox(0, 125, "Wght:", lcd.FONT_DejaVu40, 0xFFFFFF, rotate=0)
          weigh_1.zero()
          while True:
          gram.setText(str(weigh_1.weight))
          proc.setText(str(power.getBatteryLevel()))
          wait_ms(2)
          • R
            rbarsa
            When using the MQTT the simmilar problem occure. The weight value sometimes shows nonsense number.
