    Librerías ESP32 vs Arduino
    Foro español
    23.7k
    • P
      PiriX
      Buenas a todos...
      Estoy intentado correr un programa, pero me encuentro con el mensaje
      Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/WiFi
      Not used: /Applications/Arduino.app/Contents/Java/libraries/WiFi
      Cómo solventar este problema de librerías entre Arduino y ESP32?
      • O
        oscillator
        @pirix said in Librerías ESP32 vs Arduino:
        When I compile for the Core2 I also get warnings, eg:
        Used: /home/staffan/.arduino15/packages/m5stack/hardware/esp32/1.0.9/libraries/SD
        Not used: /home/staffan/Arduino/libraries/SD
        but that doesn't stop my compilation.
        Have you selected the right board in the Tools menu?
        • P
          PiriX
          Yes, I did. M5Stack-ESP32
          • O
            oscillator @PiriX
            Strange. Can you post the whole output of your compilation? Maybe there is some earlier error.
            What OS are you running?
            • P
              PiriX
              That's what I trying to run
              https://github.com/frittna/Crypto_Coin_Ticker
              I'm on a MacBook Pro 16" Intel i9, macOS Big Sur
              • P
                PiriX @oscillator
                @oscillator Arduino: 1.8.16 (Mac OS X), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
                In file included from /Users/pirix/Documents/Arduino/Crypto_Coin_Ticker-master/Crypto_Coin_Ticker/Crypto_Coin_Ticker.ino:20:0:
                /Users/pirix/Documents/Arduino/libraries/Timezone/src/Timezone.h:16:66: fatal error: TimeLib.h: No such file or directory
                Used: /Users/pirix/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/SD
                compilation terminated.
                Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
                exit status 1
                • O
                  oscillator
                  Do you have the Timezone library installed?
                  In the docs for the Timezone library it says:
                  "The Timezone library is designed to work in conjunction with the Arduino Time library, which must also be installed on your system."
                  There is also a note in the beginning of the code:
                  // !!! Library versions should match to mentioned below !!!
                  // !!!!!!!!!!!! Otherwise code won't work !!!!!!!!!!!!!!!!!
                  Do you have the right version of the libraries installed?
                  • P
                    PiriX @oscillator
                    @oscillator Exactly what they recommend
                    • O
                      oscillator
                      You seem to have prepared everything that they want...
                      Also, I am running on GNU/Linux so...sorry, can't help you...
                      • P
                        PiriX @oscillator
                        @oscillator Thank you so much for your interest!
                        • O
                          oscillator
                          Hmmm, found this: https://forum.arduino.cc/t/timelib-h-no-such-file-or-directory/413110/4
                          I know they talk about Windows, and you run OSX, but maybe this applies to you too?
                          • P
                            PiriX @oscillator
                            @oscillator Thank you!
