    M5stack and DS18B20
    3 Posts 2 Posters 6.7k Views
      fly4fun
      I wanted to measure temperatures with DS18B20 and M5stack using OneWire. Which pin do I need to connect the DATA wire (yellow)?
        Hello @fly4fun
        you are more or less free in choosing a GPIO/pin as long as it hasn't been used internally and is available on the M5Stack bus or Groove port. The OneWire library should have a means to define the GPIO/pin to be used.
        Check out M-BUS section on this page. GPIO2 or GPIO5 should be free to use.
          fly4fun @felmue
          @felmue thank you very much for your help!
