    Create new unit from existing unit?
    UIFlow
    4.4k
    • B
      bluebulldog
      How would I go about creating a new unit from an existing one?
      I would like a new unit that is similar to the RGB unit. The new unit will be an RGBW unit, and allow different color orders. Where is the RGB unit code and how would I go about making a copy, changing the copy, and have the new unit appear in UIFlow?
        Hello @bluebulldog
        AFAIK UIFlow source code is not available as open source, so I am afraid you'll need to start from scratch.
          You would need to create a new Micropython Library, copy it to the controller and then call it in code.
          If you wanted visuals blocks then you would also need to code the new blocks using the custom blocks manager.
          • B
            bluebulldog @felmue
            @felmue Thank you.
            • B
              bluebulldog @ajb2k3
              @ajb2k3 Thank you.
