    LORA-MODULE-868MHZ and LoRaWAN
    2 Posts 2 Posters 3.0k Views
      remaille
      I am using LORA-MODULE-868MHZ with LMIC stack for a device in a LoRaWAN network.
      I successfully join the network. It sends three packets and then nothing else.
      My pinmap seems correct.
      But if I look at the scematic below, DIOx are not connected...
      So my guess is that we can not do LoRaWAN with this module but only "raw LoRa".
      Am I right ? It is not clear in the documentation.
      Thanks.
      • felmueF Online
        Hello @remaille
        it should work with LoRaWAN, but as you already mentioned DIO1 needs to be connected to a GPIO on the M-Bus. I found this article (sorry, it's in German).
