Porting code from M5StickC to new Plus version
 Hi out there. For the elder M5StickC (without Plus) I wrote several applications using the old small display. Unfortunately the elder stick (with the small display)
 isnt longer avaliable so I have to switch to the new PLUS version. Although M5 says that the Plus version is fully compatible, the graphics dont work
 properly. Sure it cannot cause of the larger display. Is there any possibility to make my code compatible without re-writing all (dont need that
 bigger display) ? Thanks for any idea.
 Regards Peter
 Hello @DG4EK I'd start by replacing the M5StickC with the M5StickCPlus library and then include M5StickCPlus.hinstead ofM5StickC.hin your program. Then see what breaks (if anything) and fix that.Thanks
 Thanks Felix for the hint. Will try that and report about ...
 Regards
 Peter
