    cant flash latest m5 stamp c3
    Scheduled Pinned Locked Moved ESP - IDF
    21 Posts 4 Posters 68.9k Views
      daniyyel
      i CAN flash all other products as long as it's esp32, this one is esp32c3 and failes:
      /vol/src/esp/esp-idf/components/esptool_py/esptool/esptool.py -p /dev/ttyU1 --before default_reset --after hard_reset --chip esp32c3 erase_flash
      esptool.py v3.2-dev
      Serial port /dev/ttyU1
      Connecting...
      Failed to get PID of a device on /dev/ttyU1, using standard reset sequence.
      Chip is ESP32-C3 (revision 3)
      Features: Wi-Fi
      Crystal is 40MHz
      MAC: 7c:df:a1:a3:61:74
      Uploading stub...
      A fatal error occurred: Failed to write to target RAM (result was 01070000)
        I have this issue as well and seams to be a known issues with ESP-IDF.
        Unfortunately there is no UIFlow yet :(
          Hi guys
          I think it heavily depends on the OS you are using. On my Ubuntu 20.04 desktop installation I have no issues compiling the ESP-IDF blink example and flashing it onto my M5Stamp C3. And as an added bonus Ubuntu even has the proper USB driver pre-installed.
            daniyyel @felmue
            thanks for the info, questions:
            1- what version of idf
            2- what baudrate
              Hello @daniyyel
              1 - version of IDF: v5.0-dev-268-gf5a2fc578d
              2 - baudrate: 460800
                daniyyel
                after much work, got esp-idf to work on a Mac running Big Sur, and
                get the same error. I'm waiting to receive a esp32c3 not from M5 to see
                if it has the same issues. BTW, espressif is very silent
                bleeding edge of technology :-(
                  ajb2k3 @daniyyel
                  @daniyyel said in cant flash latest m5 stamp c3:
                  Its an issue with drivers on OSX and the change in ttl chips.
                    daniyyel
                    indeed, using different ttl-to-usb I managed to flash it. Had to manually
                    enter load mode (grounding pin 9) and now all is ok.
                    thanks
                      HaSch @daniyyel
                      thanks
                      What ttl2usb driver did you use?
                        Hi guys
                        I've just tried flashing my M5StampC3 through its built-in USB. Worked like a charm.
                        Note: I am using Ubuntu 20.04 so your mileage might vary.
                          HaSch @felmue
                          @felmue said in cant flash latest m5 stamp c3:
                          I have no chance to flash any file:
                          esptool.py v3.1
                          Serial port /dev/cu.usbmodem53220362951
                          Connecting....
                          Chip is unknown ESP32-C3 (revision 3)
                          Features: Wi-Fi
                          Crystal is 40MHz
                          MAC: 34:b4:72:12:9b:ac
                          Uploading stub...
                          Is there a usb driver missing? How to get and install?
                          BR,
                          Hans
                            Hello @HaSch
                            sorry, I don't know if you're missing a driver or not. On Ubuntu 20.04 there was no need to install a driver. Whatever is required seems to already be included in the stock version of Ubuntu 20.04.
                            I was wondering, in your case it fails while 'Uploading stub' which as I understand is not necessarily needed. In menuconfig there is an option Serial flasher config - Disable download stub which by default is unchecked. Maybe try to disable the downloading of the stub and see if that gets you any further.
                            BTW: what operation system and version are you using? Window? MacOS?
                              HaSch @felmue
                              I'm sorry, I'm using Arduino IDE and there is no menuconfig. But I have "USB CDC On Boot". Should it be enable or disable? I'm on a Mac with MacOS 10.15.7 Catalina.
                                Hello @HaSch
                                well, disabling downloading the stub doesn't help anyway - so my idea is moot. I've just setup a machine with macOS Big Sur 11.5.2 and with or w/o downloading the stub the download process ends in an timeout error.
                                What worked for me on macOS Big Sur 11.5.2 however is using the ESP32C3 built-in USB via GPIO18 and GPIO19.
                                  HaSch @felmue
                                  Hello @HaSch
                                  It really seems to be an issue with USB serial driver. I also tried to download and install the CH9102_VCP_SER_MacOS driver from here without success. Trying to install to my MacOS 10.15.7 Catalina ends up with an error:
                                  安装提示
                                  sysex didFailWithError The operation couldn’t be completed. (OSSystemExtensionErrorDomain error 9.)
                                    HaSch
                                    I urgently need a working driver for m5stamp c3 for MacOS 10.15.7 Catalina. I tried to get it work via GPIO18 and GPIO19 but don't know how because there is no driver for that on my system. Using USB-C ist throwing the known error because of the wrong or incomplete driver. Even downloading and installing the suggested driver didn't solve the problem.
                                      Hello @HaSch
                                      sorry, I cannot help you with macOS 10.15.7 Catalina. I don't own any Apple hardware recent enough to run that version of macOS. Do you have access to another computer?
                                        ajb2k3 @HaSch
                                        @hasch said in cant flash latest m5 stamp c3:
                                        Catalina is bugged since Apple released the OSX update, you need a full OSX update to 10.16 or try another TTL USB to UART adapter.
                                          HaSch @ajb2k3
                                          @ajb2k3 said in cant flash latest m5 stamp c3:
                                          It's the built in adapter of M5Stamp C3!
                                            Hello @ajb2k3
                                            As an experiment I've tried to use another TTL USB UART adapter as you suggested, but it did not work. I suspect the adapter built into the C3 is interfering with some data lines.
                                            Did you have success with another TTL USB UART adapter? If yes, how did you wire it?
