    Using atom-mate with cback-driver.
    4 Posts 2 Posters 6.5k Views
    • B Offline
      benalb
      I¡m trying to run a couple of servos with atom lite, using the atom-mate and the cback-driver for m5stick. Using platformio, I've copied CBACK_DRIVER.h and CBACK_DRIVER.cpp to the include dir in the project, modified the obvious #include <M5Atom.h>, and with this code:
      #include <M5Atom.h>
      #include "CBACK_DRIVER.h"
      bool flag = true;
      CBACK_DRIVER Driver;
      int C_BLACK = 0x000000;
      int C_WHITE = 0xffffff;
      int C_RED = 0xff0000;
      int C_GREEN = 0x00ff00;
      int C_BLUE = 0x0000ff;
              M5.begin(true, false, true);
              // let's check the atom is ok
              delay(50);
              M5.dis.drawpix(0, C_GREEN); // green
              delay(1000);
              M5.dis.drawpix(0, C_BLACK); // black
              Serial.begin(115200);
                      Driver.Init();
                      delay(1000);
                      Serial.println("C Back Driver Test...");
              if(M5.Btn.wasPressed()){
                      flag = !flag;
                      Serial.println("toggle flag value");
              if(flag){
                      for(int i=1; i<=4;i++){
                              Driver.SetServoAngle(i,90);
                              Serial.println("servo 90");
                              // Driver.ReadServoPulse(i,1500);
                      Driver.SetOutput(1);
              }else{
                              Driver.SetServoAngle(i,120);
                              Serial.println("servo 120");
                              // Driver.ReadServoPulse(i,2000);
                      Driver.SetOutput(0);
              Serial.print("PortB ADC: ");
              Serial.println(Driver.ReadADC());
              M5.update();
      I get this error:
      Building in release mode
      Linking .pio/build/m5stack-atom/firmware.elf
      .pio/build/m5stack-atom/src/main.cpp.o:(.literal._Z5setupv+0x2c): undefined reference to `CBACK_DRIVER::Init()'
      .pio/build/m5stack-atom/src/main.cpp.o:(.literal._Z4loopv+0x18): undefined reference to `CBACK_DRIVER::SetServoAngle(unsigned char, unsigned char)'
      .pio/build/m5stack-atom/src/main.cpp.o:(.literal._Z4loopv+0x1c): undefined reference to `CBACK_DRIVER::SetOutput(unsigned char)'
      .pio/build/m5stack-atom/src/main.cpp.o:(.literal._Z4loopv+0x20): undefined reference to `CBACK_DRIVER::ReadADC()'
      .pio/build/m5stack-atom/src/main.cpp.o: In function `setup()':
      /home/benalb/Projects/m5atom/cback/src/main.cpp:22: undefined reference to `CBACK_DRIVER::Init()'
      .pio/build/m5stack-atom/src/main.cpp.o: In function `loop()':
      /home/benalb/Projects/m5atom/cback/src/main.cpp:36: undefined reference to `CBACK_DRIVER::SetServoAngle(unsigned char, unsigned char)'
      /home/benalb/Projects/m5atom/cback/src/main.cpp:40: undefined reference to `CBACK_DRIVER::SetServoAngle(unsigned char, unsigned char)'
      /home/benalb/Projects/m5atom/cback/src/main.cpp:44: undefined reference to `CBACK_DRIVER::SetOutput(unsigned char)'
      /home/benalb/Projects/m5atom/cback/src/main.cpp:47: undefined reference to `CBACK_DRIVER::ReadADC()'
      collect2: error: ld returned 1 exit status
      *** [.pio/build/m5stack-atom/firmware.elf] Error 1
      ========================================================= [FAILED] Took 13.90 seconds =========================================================
      any ideas?
      • felmueF Online
        Hello @benalb
        the .cpp file should go into the src instead of the include directory, else it doesn't get compiled nor linked.
        • B Offline
          benalb @felmue
          @felmue thanks, now it compiles and uploads to the atom. But it does not work. I have also changed the ports in CBACK_DRIVER.cpp to match the ones of the atom-mate, from
          Wire.begin(0, 26);
          to
          Wire.begin(19,22);
          but no luck.
          • felmueF Online
            Hello @benalb
            according to the C Back Driver schematic the four channels are powered from the +BAT pin the M5StickC provides but is missing when using an M5Atom with the atom-mate.
