    GestureUnit with AtomLite
    Units
    4.6k
    • W
      water5
      I can't use the GestureUnit with the AtomLite.
      Is there anything I can do?
      I tried ...
      AtomLite & GestureUnit & some Arduino Lib -- failed!
      AtomLite & GestureUnit & UIFlow 1.8.9 -- failed!
      AtomLite(G25&G21 pins for i2c) & GestureUnit & UIFlow 1.8.9 -- failed!
      AtomLite & "TofUnit" & UIFlow 1.8.9 -- worked!
      M5Stack & GestureUnit & UIFlow 1.8.9 -- worked!
      M5StickPlus & GestureUnit & UIFlow 1.8.9 -- worked!
      Another AtomLite & GestureUnit & UIFlow 1.8.9 -- failed!
      I put only "gesture_0 begin" at UIFlow and I get below.
      File "flow/m5cloud.py", line 82, in _exec_fun
      File "<string>", line 6, in <module>
      File "unit.py", line 144, in get
      File "<string>", line 1, in <module>
      File "units/_gesture.py", line 20, in init
      File "units/_gesture.py", line 26, in _available
      Unit: Gesture unit maybe not connect
      Thanks!
        Hello @water5
        hmm, not sure why it would fail when used with UIFlow. I assume you selected port A for the gesture unit, correct?
        Note: there is always the possibility something's broken in UIFlow. I don't have a gesture unit so I cannot test myself whether it should work or not with UIFlow.
        For Arduino it should work after disabling internal I2C (not used in AtomLite) and starting I2C on Groove port A with this statements in setup:
          M5.begin(true, false, true); // turn off internal I2C
          Wire.begin(26, 32); // Groove I2C on port A
        • W
          water5
          Hello Felix,
          Yes, I use port A for the gesture unit.
          According to my results, I suspect that there is compatibility problem bitween AtomLite & GestureUnit.
          Does anybody use a AtomLite & a GestureUnit?
          Thanks.
            Hello @water5
            today I got my gesture unit and I can confirm that it works fine with M5Core2 but fails to work with M5AtomLite using UiFlow firmware 1.9.8.
            What I found however is, that the gesture unit starts to work with M5AtomLite as soon as I add another I2C unit. I also double-checked with an I2C scan: only gesture unit connected to M5AtomLite and the scan finds nothing. Gesture unit and PbHub connected to M5Atom and the scan finds both. Go figure...
