    SHT3x utility problem
    3.2k
    • H
      hrsavla
      I am getting these error while trying to compile helloworld example for M5 paper.
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp: In member function 'uint8_t SHT3x::UpdateDataImpl()':
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp:55:22: error: 'I2C_ERROR_OK' was not declared in this scope
      if (error != I2C_ERROR_OK)
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp:55:22: note: suggested alternative: 'SHT3x_ERROR_OK'
      SHT3x_ERROR_OK
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp:64:22: error: 'I2C_ERROR_OK' was not declared in this scope
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp:64:22: note: suggested alternative: 'SHT3x_ERROR_OK'
      SHT3x_ERROR_OK
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp: In member function 'uint8_t SHT3x::SendMeasurementCommand()':
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp:86:21: error: 'class TwoWire' has no member named 'lastError'
      return Wire.lastError();
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp:90:21: error: 'class TwoWire' has no member named 'lastError'
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp: In member function 'uint8_t SHT3x::ReceiveResult(uint8_t*)':
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp:101:16: error: 'I2C_ERROR_TIMEOUT' was not declared in this scope
      return I2C_ERROR_TIMEOUT;
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp:101:16: note: suggested alternative: 'ESP_ERR_TIMEOUT'
      ESP_ERR_TIMEOUT
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp:103:12: error: 'I2C_ERROR_OK' was not declared in this scope
      return I2C_ERROR_OK;
      C:\Users\DELL\OneDrive\Documents\Arduino\libraries\M5EPD\src\utility\SHT3x.cpp:103:12: note: suggested alternative: 'SHT3x_ERROR_OK'
      SHT3x_ERROR_OK
      Multiple libraries were found for "WiFiClient.h"
      Used: C:\Users\DELL\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.0.1\libraries\WiFi
      Not used: D:\arduino-1.8.18\libraries\WiFi
      Used: C:\Users\DELL\AppData\Local\Arduino15\packages\m5stack\hardware\esp32\2.0.1\libraries\SD
      Not used: D:\arduino-1.8.18\libraries\SD
      exit status 1
      Error compiling for board M5Stack-Paper.
        Hello @hrsavla
        there are multiple issues to fix this for compilation with Arduino framework 2.0.1.
        I've attempted to solve those issues here - try it at your own risk.
