    Arduino IDE Configuration for Core2
    5 Posts 2 Posters 8.5k Views
      jdonth
      I have the following additional boards in my Arduino Preferences:
      https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/arduino/package_m5stack_index.json
      Do I need any other additional board libraries to successfully compile a Core2 project?
        Hello @jdonth
        that boards URL worked for me.
        Here are the steps for the M5Core2 factory test. And yes, I have speaker output and the mic works too.
        Note: I am on Ubuntu 20.04
        • Download and install Arduino IDE 1.8.19
        • Run Arduino IDE
        • Open Preferences
          • Add Additional Board Manager URL and Save
            • https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/arduino/package_m5stack_index.json
        • Open Boards Manager
          • Search for 'M5Stack'
          • Install M5Stack v2.0.1 <-- (if you want to try an earlier version change this to let's say v1.0.8 - then you can copy all the files and skip fixing the sketch)
        • Open Library Manager
          • Search for 'M5Core2'
          • Install M5Core2 v0.1.0 (I selected install M5Core2 only)
        • Save already open Sketch as 'Core2_Factory_test'
        • Close Arduino IDE
        • Copy all M5Core2 factory test files into <home>/Arduino/Core2_Factory_test (except ft6336_fw_updater.cpp - has errors when using v2.0.1)
        • Open Arduino IDE
        • Select Board: 'M5Stack-Core2'
        • Fix Sketch (only needed when using v2.0.1):
          • In Setup():
            • comment out: ft6336_fw_updater();
          • In InitI2SSpakerOrMic():
            • after the line: tx_pin_config.data_in_num = CONFIG_I2S_DATA_IN_PIN;
            • add this line: tx_pin_config.mck_io_num = GPIO_NUM_0;
        • Compile Sketch (ignore warnings)
        • Connect M5Core2
        • Select port
        • Download and Run Sketch
        J 2 Replies Last reply Reply Quote 0
          jdonth @felmue
          OMG! It worked!!!!
          Thank you, thank you, thank you.
          Joe
            jdonth @felmue
            These instructions should be posted as a Core2 Sticky. They would go a long way to provide an outstanding starting point for all the new M5Core2 developers.
              Hello @jdonth
              happy to hear it finally works for you. Thank you for letting me know.
              Happy New Year!
