    difficulty to generate interrupt signal with G26 on M5StickC Plus
    2 Posts 2 Posters 3.1k Views
      Marco.Cantoni
      I feel embarrassed to ask for such a stupid issue:
      I cannot get a simple button attached to G26 (pressed: G26->GND) generate an interrupt and light up the on board LED. With digitalRead it works. I want to use the interrupt version to read pwm signals eventually.
      I am using Arduino-IDE.
      Here is my code:
      #include <M5StickCPlus.h>
      /* pin that is attached to interrupt */
      uint8_t interruptPin = 26;
      void pressed() {
      digitalWrite(10, LOW); // LED on
      delay(100);
      digitalWrite(10,HIGH); // LED off
      // when pin G26 goes low, call the pressed function
      pinMode(interruptPin,INPUT_PULLUP);
      attachInterrupt(digitalPinToInterrupt(interruptPin), pressed, LOW);
      pinMode(10,OUTPUT);
      digitalWrite(10, HIGH); // LED off to start with
      // put your main code here, to run repeatedly:
        Hello @Marco-Cantoni
        try FALLING instead of LOW when calling attachInterrupt().
