Problem about M5stack GPS
I'm trying to use M5Stack GPS now and I have a problem.I tried the example from the arduino Examples/Modules/FullExample. I had tried a few days still cannot fix the problem.
Here is the outcome of serial monitor.
And the outcome in the M5Stack is "No GPS data received: check wiring".Is that mean my GPS can't get data? How can I fix it?
Thanks a lot! -
@ken57093 From your picture it looks like the baud rate maybe set wrong on your serial monitor. It should be 115200 baud
@lukasmaximus Thanks a lot!
I can see the data in serial monitor now. But in my M5Stack, it still show that "No GPS data received: check wiring". Do you have any idea?
The gpsmodul is from Navspark and the output is not equal NMEA .
Sample: $GNRMC but not $RMC.
The libraries TinyGPS++ and TinyGPS can not work with the output.
