    Core2, W5500 and ESP-IDF example eth2ap
    Core 2
    5.1k
      sheepDog
      I like to use a Core2 as Wifi-AP for some small sensors. My starting point was the eth2ap example from ESP-IDF v4.3.2. I added some outputs to the example to see was going on. I changed FLOW_CONTROL_QUEUE_TIMEOUT_MS to 500:
      #define FLOW_CONTROL_QUEUE_TIMEOUT_MS (5*100)
      #define FLOW_CONTROL_QUEUE_LENGTH (40)
      #define FLOW_CONTROL_WIFI_SEND_TIMEOUT_MS (100)
      typedef struct {
          void *packet;
          uint16_t length;
      } flow_control_msg_t;
      // Forward packets from Wi-Fi to Ethernet
      static esp_err_t pkt_wifi2eth(void *buffer, uint16_t len, void *eb)
          if (s_ethernet_is_connected) {
              if (esp_eth_transmit(s_eth_handle, buffer, len) != ESP_OK) {
                  ESP_LOGE(TAG, "Wifi->ETH: Ethernet send packet failed");
          esp_wifi_internal_free_rx_buffer(eb);
          return ESP_OK;
      // Forward packets from Ethernet to Wi-Fi
      // Note that, Ethernet works faster than Wi-Fi on ESP32,
      // so we need to add an extra queue to balance their speed difference.
      static esp_err_t pkt_eth2wifi(esp_eth_handle_t eth_handle, uint8_t *buffer, uint32_t len, void *priv)
          esp_err_t ret = ESP_OK;
          flow_control_msg_t msg = {
              .packet = buffer,
              .length = len
          if (xQueueSend(flow_control_queue, &msg, pdMS_TO_TICKS(FLOW_CONTROL_QUEUE_TIMEOUT_MS)) != pdTRUE) {
              ESP_LOGE(TAG, "ETH->Wifi: send flow control message failed or timeout, length=%d", len);
              free(buffer);
              ret = ESP_FAIL;
          return ret;
      // This task will fetch the packet from the queue, and then send out through Wi-Fi.
      // Wi-Fi handles packets slower than Ethernet, we might add some delay between each transmitting.
      static void eth2wifi_flow_control_task(void *args)
          flow_control_msg_t msg;
          int res = 0;
          uint32_t timeout = 0;
          while (1) {
              if (xQueueReceive(flow_control_queue, &msg, pdMS_TO_TICKS(FLOW_CONTROL_QUEUE_TIMEOUT_MS)) == pdTRUE) {
                  timeout = 0;
                  if (s_sta_is_connected && msg.length) {
                      do {
                          vTaskDelay(pdMS_TO_TICKS(timeout));
                          timeout += 2;
                          res = esp_wifi_internal_tx(WIFI_IF_AP, msg.packet, msg.length);
                      } while (res && timeout < FLOW_CONTROL_WIFI_SEND_TIMEOUT_MS);
                      if (res != ESP_OK) {
                          ESP_LOGE(TAG, "ETH->WiFi: send packet failed: %d, timeout=%d, length=%d", res, timeout, msg.length);
                      else {
                          ESP_LOGI(TAG, "ETH->WiFi: send packet ok: %d, timeout=%d, length=%d", res, timeout, msg.length);
                  free(msg.packet);
          vTaskDelete(NULL);
      It worked sometimes: If I send 10 pings, 2-3 reached the server. I cann't used a browser to show some small html-page.
      My output is:
      I (14004) wifi:new:<1,0>, old:<1,1>, ap:<1,1>, sta:<255,255>, prof:1
      I (14004) wifi:station: 5e:6c:e2:e0:0f:66 join, AID=1, bgn, 20
      I (14034) eth_example: Wi-Fi AP got a station connected
      I (14074) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (14104) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (14174) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (14204) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      E (16534) eth_example: ETH->WiFi: send packet failed: 12309, timeout=100, length=60
      I (16534) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (16544) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (16554) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=590
      I (16554) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (16564) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (16574) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (16584) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=86
      I (16584) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=295
      I (16594) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (16604) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=770
      I (16614) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (16614) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=1314
      I (16624) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=86
      I (16634) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=88
      I (16644) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (16644) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=590
      I (16654) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=812
      I (16664) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=832
      I (16674) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=316
      I (16674) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=336
      I (16684) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=1168
      I (16694) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=1188
      I (16704) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=1398
      I (16704) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=1418
      I (16714) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=86
      E (18974) eth_example: ETH->WiFi: send packet failed: 12309, timeout=100, length=60
      I (18974) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (18984) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (18994) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (19004) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (19014) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (19024) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=88
      I (19034) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=74
      I (19044) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (19044) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=590
      I (19054) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (19064) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      E (21324) eth_example: ETH->WiFi: send packet failed: 12309, timeout=100, length=60
      I (21324) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (21334) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (21344) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=316
      I (21344) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=336
      I (21354) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=590
      I (21364) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=812
      I (21374) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=832
      I (21374) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=1398
      I (21384) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=1418
      I (21394) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=1168
      I (21404) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=1188
      I (21404) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (21414) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (21424) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (21434) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=88
      I (21434) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=107
      I (21444) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=131
      I (21454) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=86
      I (21464) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (21464) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=86
      I (21474) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=86
      I (21484) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (21494) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (21494) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=705
      I (21504) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (21514) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      E (22494) eth_example: ETH->Wifi: send flow control message failed or timeout, length=832
      E (22994) eth_example: ETH->Wifi: send flow control message failed or timeout, length=1398
      E (23494) eth_example: ETH->Wifi: send flow control message failed or timeout, length=1418
      E (23774) eth_example: ETH->WiFi: send packet failed: 12309, timeout=100, length=60
      I (23774) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (23784) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (23794) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (23794) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=86
      I (23804) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (23814) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=191
      I (23824) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=191
      I (23824) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=86
      I (23834) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=60
      I (23844) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=86
      I (23854) eth_example: ETH->WiFi: send packet ok: 0, timeout=2, length=750
      Have anyone used the ESP32 as WiFi-AP and knows the challenges?
        Hello @sheepDog
        the eth2ap sample code runs fine on my M5Core2 w/o any modifications except adapting the GPIOs. Ping are fine and I can surf the Internet just fine from the wireless cleint.
        • Have you tried to change the channel the softAP is using? Maybe there is too much interference in your area?
        • Have you tried with a different wireless client?
        • How are you powering the M5Core2 and LAN module? Maybe there is a power issue?
          sheepDog
          Hello Felix,
          thank you for your quick answer. I can ping sometimes and I cann't surf the Internet with my phone or with my computer and eth2ap-modul.
          • I have changed the channel the softAP is using. Small changes in quality can be seen, but no significant improvement.
          • I tried a different wireless client, for example my computer and my phone.
          • I used a 12V/3A power adapter on LAN-Module with W5500. The M5Core2 and the LAN module also run stably with other applications and the same power supply.
          Bye,
          Uwe
