Random restarts of the M5Stack Core 2 (code/backtrace included)
Hi! I am building a tower light. It has the following features:
- Battery (AXP125)
- 3 x 12 5050 Neopixel rings
- Enclosure that fits the M5Stack Core 2
- OOB, it goes into config mode (AP mode) and has a web interface to 'scan' and join a WiFi network as a client
- RESTful API for controlling the lights
I've been having random reboots of the M5Stack Core 2 using tasks. I've stripped down 99% of my code to a simple example. Any ideas how I can figure out whats causing the restarts?
Also, M5.BtnA.wasPressed() doesn't work either when the button is pressed.
My code:
#include <Arduino.h> #include <M5Core2.h> #include <Adafruit_NeoPixel.h> #include "logo.h" // create a couple task handles TaskHandle_t TaskBtnScr; TaskHandle_t Task2; //BtnScrController: Displays sprite output and looks for button presses void BtnScrController( void * pvParameters ){ for(;;){ // emulate a void loop() M5.update(); if (M5.BtnA.wasPressed()) { Serial.println("Button was pressed."); delay(1000); } } } //Task2code: blinks an LED every 700 ms void Task2code( void * pvParameters ){ Serial.print("Task2 running on core "); Serial.println(xPortGetCoreID()); for(;;){ M5.Lcd.clearDisplay(); M5.Lcd.setCursor(0, 0); M5.Lcd.setTextColor(WHITE); M5.Lcd.println("task 2 code"); delay(2500); } } void setup() { M5.begin(true, true, false, true, kMBusModeOutput); Serial.begin(115200); // logo M5.Lcd.pushImage(0, 0, 320, 240, (uint16_t *)gImage_logo); delay(2500); M5.Lcd.clearDisplay(); M5.Lcd.setCursor(0, 0); M5.Lcd.setTextColor(WHITE); //create a task that will be executed in the Task1code() function, with priority 1 and executed on core 0 xTaskCreatePinnedToCore( BtnScrController, /* Task function. */ "ButtonScreenController", /* name of task. */ 10000, /* Stack size of task */ NULL, /* parameter of the task */ 1, /* priority of the task */ &TaskBtnScr, /* Task handle to keep track of created task */ 0); /* pin task to core 0 */ delay(500); //create a task that will be executed in the Task2code() function, with priority 1 and executed on core 1 xTaskCreatePinnedToCore( Task2code, /* Task function. */ "Task2", /* name of task. */ 10000, /* Stack size of task */ NULL, /* parameter of the task */ 1, /* priority of the task */ &Task2, /* Task handle to keep track of created task */ 1); /* pin task to core 1 */ delay(500); } void loop() { }Terminal:
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:1044 load:0x40078000,len:10124 load:0x40080400,len:5828 entry 0x400806a8 [E][sd_diskio.cpp:194] sdCommand(): Card Failed! cmd: 0x00 [E][sd_diskio.cpp:775] sdcard_mount(): f_mount failed: (3) The physical drive cannot work [E][sd_diskio.cpp:194] sdCommand(): Card Failed! cmd: 0x00 Task2 running on core 1 E (19249) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time: E (19249) task_wdt: - IDLE0 (CPU 0) E (19249) task_wdt: Tasks currently running: E (19249) task_wdt: CPU 0: ButtonScreenCon E (19249) task_wdt: CPU 1: loopTask E (19249) task_wdt: Aborting. abort() was called at PC 0x400e7717 on core 0 ELF file SHA256: 0000000000000000 Backtrace: 0x4008a490:0x3ffbe4f0 0x4008a709:0x3ffbe510 0x400e7717:0x3ffbe530 0x40086195:0x3ffbe550 0x4000cffa:0x3ffb4600 0x40081573:0x3ffb4620 0x400d1d70:0x3ffb4640 0x400d1ee5:0x3ffb4690 0x400d15f5:0x3ffb46b0 0x400d14ca:0x3ffb46d0 0x4008b70e:0x3ffb46f0 Rebooting... ets Jul 29 2019 12:21:46 rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0018,len:4 load:0x3fff001c,len:1044 load:0x40078000,len:10124 load:0x40080400,len:5828 entry 0x400806a8 [E][sd_diskio.cpp:194] sdCommand(): Card Failed! cmd: 0x00 [E][sd_diskio.cpp:775] sdcard_mount(): f_mount failed: (3) The physical drive cannot work [E][sd_diskio.cpp:194] sdCommand(): Card Failed! cmd: 0x00 Task2 running on core 1 E (19249) task_wdt: Task -
Hello @JackRazors
to avoid the crash add a
delay(1)into theforloop of theBtnScrController()task function. This allows the system to reset the watchdog.Thanks
Felix -
I don't know if you got this sorted, but we're not really supposed to user core 0, as this can cause panics. That's advice from Espressif. Also, adding in a delay @felmue said should really help in allowing the thread to free-up some cycles.
