    GPIO16 as input not working?
    Cores
    5.8k
    • T
      Thomasx
      Hi
      I am trying to use GPIO16 as input on an M5Stack Core, but it does not work.
      I tried using GPIO35 instead and that worked fine.
      But I want this signal on GPIO16. Any ideas on how to make that work?
      When searching for info on this I have not found any info that it shouldn't work. In general it says that it should work to use GPIO16 both as output and input.
      I am using GPIO17 as output and that is working fine.
        Hello @Thomasx
        judging from your other posts I assume you mean M5Core2 (the one with touch interface). If so on M5Core2 GPIO16 and GPIO17 are used internally for PSRAM - they cannot be used for anything else.
        Note: if for whatever reason you really need GPIO16 as output you'd need to switch to an M5Stack (Basic, Go or Gray). Not M5Stack Fire as it also has PSRAM.
          macsbug
          GPIO is written in PinMap of M5Unified.
          M5Unified:PinMap
          https://github.com/m5stack/M5Unified
