ATOM TF-CARD Kit SPI pins are not default SPI pins?
I just wanted to ask if the pins used for SD card interface on ATOM TF-CARD Kit are just GPIO pins and they not default SPI pins of ESP32 Pico?
Because I tried to use it with esp-idf and it does not work. Because SD card driver of esp-idf uses default SPI pins.Can you please suggest any way to use ATOM TF-CARD Kit with esp-idf?
How to use the ATOM TF-Card in Python?
I tried to mount the TF-CARD as below with my ATOM Matrix but it when I load my code I get a red cross on the display. (I use cs=21 because it is not used in the ATOM)
import uos
uos.sdconfig(uos.SDMODE_SPI,clk=23,mosi=19,miso=33,cs =21)
uos.mountsd() -
Hello @pieter
this works for me:
from machine import SDCard from machine import Pin import os try: sd = SDCard(slot=3, miso=Pin(33), mosi=Pin(19), sck=Pin(23), cs=Pin(4)) sd.info() os.mount(sd, '/sd') print("SD card mounted at \"/sd\"") except (KeyboardInterrupt, Exception) as e: print('SD mount caught exception {} {}'.format(type(e).__name__, e)) pass print(os.listdir('/sd'))Note: mostly taken from
boot.pyfrom an M5Core2 with modified pin config. CS pin is not really required as the SD card always selected anyways.Thanks
Felix -
@felmue said in ATOM TF-CARD Kit SPI pins are not default SPI pins?:
sd.info()
Hi Felix,
Thanks a lot.
Your solution also works for me.
