    MicroPython
    Core 2
    4.4k
    • N
      nicolai
      Good morning everyone,
      I am here to see if I can solve this problem since I do not know if the libraries used by M5stack are out of date since I try to use elements provided by M5stack and when I go to implement them in the code I get many errors that are not mine.
      Attached page of the examples that if they are good but they are not complete:
      • https://docs.m5stack.com/en/mpy/display/m5stack_lvgl
      Here you will find several examples but there is no event code.
      I see that M5stack core 2 with micropython is adapted with the library 'lvgl' attached guide page:
      • https://docs.lvgl.io/master/examples.html
      I observe different examples where I can only rescue some examples that work but others do not work since the libraries are not complete in my opinion, I attach examples that I provide but they do not work and they are:
      EXAMPLES PAGE:
      SIMULATOR:
      https://sim.lvgl.io/v8.1/micropython/ports/javascript/index.html?script_startup=https://raw.githubusercontent.com/lvgl/lvgl/71e6f65d519443b2c72a4b1b0b495dcfbc0fc91f/exadersader/exader/exader/examples/ //raw.githubusercontent.com/lvgl/lvgl/71e6f65d519443b2c72a4b1b0b495dcfbc0fc91f/examples/widgets/chart/lv_example_chart_1.py
      CHART:
      • https://docs.lvgl.io/master/widgets/extra/chart.html?highlight=chart
      • https://github.com/lvgl/lvgl/blob/71e6f65d519443b2c72a4b1b0b495dcfbc0fc91f/examples/widgets/chart/lv_example_chart_6.py
      When wanting to use these examples it says that the library does not exist, then I go to the program m5burn version 2.4.2 and I have the version of micropython 1.8.4 core2, I would like to know please what I have to do so that no error of the examples that appear there I did not go out again.
      Thank you very much Community.
      • W
        WoeTan
        Hey good afternoon
        I am trying to use also the LVGL and its charts on the Core2.
        I have the version 1.9.2 installed.
        I have created an example, which should work.
        The API documentation i have linked, documents other functions as implemented.
        import lvgl as lv
        chart = lv.chart(lv.scr_act())
        chart.set_size(200, 150)
        chart.set_type(lv.chart.TYPE.LINE) # Line Mode
        chart.set_point_count(20)
        chart.set_y_range(lv.chart.AXIS.PRIMARY_Y,0,120)
        chart.set_style_local_line_width(lv.chart.PART.SERIES,0,1) #Line Width of Dataserie 0
        chart.set_style_local_size(lv.chart.PART.SERIES,0,1) # Point Width
        ser1 = chart.add_series(lv.color_hex(0x000000)) # Add data serie
        chart.set_next(ser1,1) # Set next points on ser1
        chart.set_next(ser1,2)
        chart.set_next(ser1,10)
        chart.set_next(ser1,30)
        chart.set_next(ser1,70)
        chart.set_next(ser1,110)
        Late response, i know, but i hope it helps you.
        Best regards
