    Newbie at ALL. Be patient.
    8 Posts 3 Posters 13.8k Views
      peixoto1970
      Hi all.
      I just bought Core2 and StickC devices. I am using uiFlow/Block and its nice, I want to get better on programming.
      Thanks for your help.
      Is Python the same on all devices? M2Core, StickC ....
      What the best site to start learning Python used in M5stack devices?
      Is there a way to use uiFlow/Blocky on regular ESP32 devices, like TTGo Display one.
      Thanks, I am glad to be here.
      M5stack Core2, StickC and some units.
        There are sever generic books on micropython and esp32 however my work in progress book is found here: https://github.com/Ajb2k3/UIFlowHandbook/blob/master/UIFlowhandbook.pdf
          aafortinet
          @ajb2k3 I downloaded your PDF. I can't access the micropython REPL. Is it meant to be available on M5 CoreInk?
          • I tried baud date 115200 and 921600.
          • my device is on /dev/ttyUSB0 (that's what I use for Arduino to program it).
          • I tried picocom and screen. They both appear blocked, never showing the REPL, even after trying Ctrl-A.
          Thanks.
            Try thonny but its normally USBtoUART and its CTRL+C
              aafortinet @ajb2k3
              @ajb2k3 no, /dev/USBtoUART does not exist on my host. It is /dev/ttyUSB0. Tried thonny, not better than picocom or screen. I think the software is not the issue. Am I meant to have a specific firmware on the device for micropython to work?
                have you installed the correct usb driver?
                  aafortinet @ajb2k3
                  @ajb2k3 yes. I program it with Arduino, no problem.
                    aafortinet @aafortinet
                    Found my error. I had flashed the M5 with a program of my own using Arduino. Using the UI Flow firmware, I get the Micropython REPL no problem with screen /dev/ttyUSB0 115200.
