    UIFlow 2.0.2 firmware preview version
    14 Posts 9 Posters 32.5k Views 2 Watching
    • m5stackM Offline
      Hi everyone, new firmware is coming, we support ESP32C3 now.
      Preview:
      UIFlow 2.0.0 firmware preview version
      UIFlow 2.0.1 firmware preview version
      Firmware:
      • uiflow-b061698-esp32-4mb-20220304.bin
      • uiflow-b061698-esp32-spiram-4mb-20220304.bin
      • uiflow-b061698-esp32c3-4mb-20220304.bin
      • uiflow-b061698-esp32c3-usb-4mb-20220304.bin
      How to write firmware:
      Please download the above firmwares, use esptool or Flash Download Tools to write the firmware at offset 0x1000.
      esp32
      esptool.py --chip esp32 --port /dev/ttyUSBx --baud 1500000 write_flash 0x1000 uiflow-b061698-esp32-4mb-20220304.bin #uiflow-b061698-esp32-spiram-4mb-20220304.bin
      esp32c3(STAMP-C3, STAMP-C3U)
      esptool.py --chip esp32c3 --port /dev/ttyUSBx --baud 1500000 write_flash 0x0 uiflow-b061698-esp32c3-4mb-20220304.bin
      # if you flash the firmware through the USB port, you need press the button A before you plug USB cable enter the download mode
      esptool.py --chip esp32c3 --port /dev/ttyUSBx --baud 1500000 write_flash 0x0 uiflow-b061698-esp32c3-usb-4mb-20220304.bin
      P.S.
      Follow M5STACK on twitter for the latest news about UIFlow 2.0 new update.
      • Z Offline
        Zetabyte
        Thank you for the update. Look like you've upgraded to 1.18, that's nice, that should speedup some dict loops.
        Is there any documentation to the m5 package? Or do you have a changelog or something? Or can yoi upload the sources to github, so that we at can look for ourself for the functions?
        • Z Offline
          Zetabyte
          Found a bug.
          >>> import io
          ValueError: incompatible .mpy file
          Edit: It helped to delete the io.mpy file under libs/micropython
            M5Stack_AG @Zetabyte
            @zetabyte Hi there, please wait for the UIflow 2.0
              mory
              会支持tab控件吗?
                mm-uiflow
                how is the status of this? is the update comming soon? is it stable yet?
                • m5stackM Offline
                  m5stack @mory
                  @mory
                  uiflow-lvgl-2.0-xxx 会支持lvgl的所有控件(应该)
                  • m5stackM Offline
                    m5stack @mm-uiflow
                    @mm-uiflow
                    Sorry, still under developing, UIFlow 2.0 it's big project, not only the firmware.
                      Hello @m5stack
                      anything the M5Stack community can help with?
                        Costas
                        Trying to get I2C to work on the new firmware. I have M5's SGP30 sensor. MicroPython is not detecting anything plugged in. Guidance?
                        from machine import SoftI2C, Pin
                        i2c = SoftI2C(sda=machine.Pin(21),scl=machine.Pin(22),freq=100000)
                        devices = i2c.scan()
                        devices = [52, 53, 56, 81, 104], the SGP30 should be on 58, right?
                          ajb2k3 @Costas
                          @costas softI2c?
                          Use I2C not softI2c
                            Costas
                            Same results.
                            from machine import I2C, Pin
                            i2c = I2C(scl=Pin(22), sda=Pin(21), freq=100000)
                            i2c.scan()
                              Hello @Costas
                              from the scan result I suspect you are using an M5Core2, correct?
                              The M5Core2 has an internal (GPIO21/22) and an external (GPIO32/33) I2C bus.
                              Right now your code scans the internal I2C bus, but the SGP30 is connected to port A (external I2C bus), so you need to change your code to scan the external I2C bus.
                              • IAMLIUBOI Offline
                                IAMLIUBO
                                THIS TOPIC WAS ABANDONED.
                                Please check this new topic and discuss。
