    Mis-match between M5stack Core2 version and flow.m5stack.com
    8 Posts 3 Posters 9.5k Views 1 Watching
      david-bethesda
      My device has 1.9.3 but when I go to flow.m5stack.com I see 1.4.5 I have run M5Burn a couple of times. How do I fix this? Thanks.
        ajb2k3 @david-bethesda
        @david-bethesda Click on the icon of the 3 horizontal line to open settings, click on VER and change to beta
          david-bethesda @ajb2k3
          @ajb2k3 Thanks! So should we be using the web-based UIFlow, or the desktop client?
          I am having great trouble finding organized, clear and complete documentation.
            @david-bethesda web as desktop app is out of date
              @ajb2k3 The instructions you gave, to change the Version to Beta, only apply to the web app, but then you say the web app is out of date. Therefore it's unclear whether I should be using the desktop or web UI. Thanks. Note: I just found that I can use flow.m5stack.com UI, it shows 1.9.3 version upper left, which matches my device version. I can't figure out how to get the desktop software to 1.9.3. Oh well.
                Hello @david-bethesda
                I think you might have misread @ajb2k3's answer. What he meant is to use the web UI (because the Desktop app version is out of date).
                Note: the Desktop app version has not been updated in ages - I would not recommend to use it.
                D 1 Reply Last reply Reply Quote 2
                  @david-bethesda sorry, replied on a mobile and it got garbled.
                    david-bethesda @felmue
                    @felmue Ok, so I'm using the Web IDE successfully but only in WiFi mode, I can't figure out how to connect a USB device while using web IDE, only desktop IDE (which I understand now is no longer maintained). I am doing this because for use in a school environment they only have "captive" WiFi.
