    multiple 4-Relays on same I2C bus
    5 Posts 3 Posters 5.5k Views
    • bartblommaertsB Offline
      bartblommaerts
      Is there a way to control more then 1 4-relay units with a StickC+ ?
        Hello @bartblommaerts
        from what I can tell the 4-relay unit has a fixed I2C address (0x26) so connecting more than one directly doesn't work (I2C address conflict).
        However you should be able to control multiple 4-Relay units through a PaHub2.
        Note: I do not have the necessary units to test whether it actually works or not. My conclusion is solely from looking at the documentation.
          ajb2k3 @felmue
          @felmue said in multiple 4-Relays on same I2C bus:
          @felmue is correct. The Address is hard coded and so you need to use the I2C hub for more that 1 unit.
            bartblommaerts
            Oh the PaHub>2< Unit :/
            its not available yet in the local stores. And the Pa.Hub (version 1) is sold out.
              ajb2k3 @bartblommaerts
              @bartblommaerts said in multiple 4-Relays on same I2C bus:
              You're better off ordering direct from M5Stack
