    Arduino IDE on Mac High Sierra - is it supported?
    5 Posts 2 Posters 6.7k Views
    • W Offline
      wsanders
      I am trying to compile my first "hello world" type program for the M5stick-C-Plus using the Arduino IDE. I get the error:
      [2327] Error loading Python lib '/var/folders/yw/dk6xgyd93vjbcglyz6tcmgvr0000gn/T/_MEIcUowqf/libpython3.8.dylib': dlopen: dlopen(/var/folders/yw/dk6xgyd93vjbcglyz6tcmgvr0000gn/T/_MEIcUowqf/libpython3.8.dylib, 10): Symbol not found: ____chkstk_darwin
      Referenced from: /var/folders/yw/dk6xgyd93vjbcglyz6tcmgvr0000gn/T/_MEIcUowqf/libintl.8.dylib (which was built for Mac OS X 10.15)
      Expected in: /usr/lib/libSystem.B.dylib
      in /var/folders/yw/dk6xgyd93vjbcglyz6tcmgvr0000gn/T/_MEIcUowqf/libintl.8.dylib
      exit status 255
      /Applications/Arduino.app/Contents/Java/arduino-builder returned 255
      Error compiling for board M5Stick-C-Plus.
      Does this mean than compiling for M5stack devices under Arduino IDE requires Mac OS 10.15? I am running High Sierra (10.13.6).
      w
      • W Offline
        wsanders
        High Sierra has Python 2 installed with the OS, so this looks like a dependency on Python3. I could install Python3 from python.org, but I doubt it would work.
        I will give it a try in Linux, where Python3 has been standard for a long time.
        I'll propose a new question: What is the easiest way to get an M5Stack IDE working on an old Mac? I'm language neutral, C++, Python, even UIFlow is fine with me.
          ajb2k3 @wsanders
          @wsanders You need to install Python 3 and configure the environmental path.
          Mac still defaults to py2 which is depreciated for modern none apple software.
          • W Offline
            wsanders
            Is there a particular environment variable that is used to point the IDE to Python3? One does not simply alter the PATH or LD_LIBRARY_PATH in one's shell or alias the "python" command to "python3", because older MacOS is very dependent on Python 2. I installed Python 3 with brew a few years ago and it hosed my system badly enough to warrant an OS reinstall.
              ajb2k3 @wsanders
              @wsanders I just followed the install instructions to install Python3 in OSX
              All you are doing is adding a list of folders that tell the terminal where to look for python 3.
              Something like this guide works fine: https://www.educative.io/edpresso/how-to-add-python-to-the-path-variable-in-mac
              Then once the variable is set you use python3 instead of python when issuing commands.
