    http - get method - It does not send pairs name-value
    4 Posts 4 Posters 9.7k Views 1 Watching
      mario
      I am an accredited rookie ;-)
      When I try to send data through http, with the get method, it doesn't send the names and values pairs.
      UIflow with blocks:
      When I look at the code, I don't see it send the string with the name and value pair.
      According to this web page, the program would have to send you the data arguments.
      https://makeblock-micropython-api.readthedocs.io/en/latest/public_library/Third-party-libraries/urequests.html#urequests.request
      I have tried to write by hand, without success.
      Have any of the readers succeeded, send data to a server via http?
      This is the server code, written for node js, in case you want to try it at: https://repl.it/ o en https://glitch.com/
      var http = require('http');
      var url = require('url');
      var x_gyr = 0.0;
      /* https://echo-data-get-method-http-get.mariomoreno2020.repl.run/t.htm?x=15 */
      http.createServer(function (req, res) {
        // Set CORS headers
      	res.setHeader('Access-Control-Allow-Origin', '*');
      	res.setHeader('Access-Control-Request-Method', '*');
      	res.setHeader('Access-Control-Allow-Methods', 'OPTIONS, GET, POST, PUT');
      	res.setHeader('Access-Control-Allow-Headers', '*');
        res.statusCode = 200;
        res.writeHead(200, {'Content-Type': 'text/html'});
        var q = url.parse(req.url, true);
        console.log(q.href);
        if (q.pathname == '/t.html') {
          q = q.query;
          x_gyr = q.x;
        var txt = 'x= ' + x_gyr;
        res.end(txt);
      }).listen(8080);
      Remember that the http block, the url is 'http' instead of 'https'.
      And if you want to try the UIFlow code, here is a download link. You can see how in the blocks it sends data and in the python code no.
      https://mega.nz/#!YY82UIrB!fskiB3YAn1hQH6rCcbwzjiuJO5-Fz0H4LBr6LZ4WtjI
      • U Offline
        uecken
        I got same problem.
        Here is my UiFlow code and server console.
          Try placing the map functions inside the conver to JSON blocks.
          • E Offline
            epollari @uecken
            @uecken Replace the text box containing the URL with an unescaped text box. That way, the URL won't get truncated. See also this post: HTTP GET query parameters
