    IP in m5stack
    Core 2
    7.8k
    • J
      Javi
      How can I set a static IP to the device when I connect it to a wifi network ?
      Thanks.
        Hello @Javi
        try calling WiFi.config() before starting the network with WiFi.begin().
        See here for an example.
        • J
          Javi
          hi @felmue
          but that example only works for Arduino connection? I would like to do it in python.
          • J
            Javi
            hi again @felmue
            Do you think there is any sense in using this in python "wifiCfg.wlan_sta.ifconfig()" setting the ip parametres inside the parenthesis?
              Hello @Javi
              yes, my suggestion is for Arduino. For Micropython I found this post.
              • J
                Javi
                Thank you @felmue I´ll try to use that.
