    Core2 no display functions
    6 Posts 4 Posters 8.7k Views
      simmoe
      This is so simple, its unbelievable it really happens. I turn on a brandnew Core2, connect with UIFlow, drag a labet to the screen and hit Run. Screen stays white.
        Hello @simmoe
        have you tried anything else, e.g. changing the screen background for instance? Does that work?
          Have you installed the latest Core2 firmware and not the latest Core firmware?
          K 1 Reply Last reply Reply Quote 1
            Kent Ong @ajb2k3
            @ajb2k3 I ve encountered this issue. It seems it is the browser issue. I change to use MS edge and it works. hence i switch here and there.
              simmoe @Kent Ong
              @kent-ong @felmue @ajb2k3
              SOLVED - KINDA
              Yes, this is a browser issue - and a BUG really
              Changing the browser WILL solve the problem - temporarily - until you open a NEW TAB with another uiflow instance and another M5 connection, i.e an M5Stick. Apparently the underlying issue is that the browser (caches, cookies?) saves some display settings, i.e FONTS etc, and this causes the WSOD.
              M5 team - fix this stuff man, it makes the product seem so unreliable when it's really just a bad web-coding issue
                I'm not sure what changed but last year something did and you can only run one instance at a time connected to a controller. If you open a second connection to another controller it does in deed cause problems, which is a pain as I used to run two controllers at a time for testing.
