    Error with M5 echo example
    3 Posts 2 Posters 4.5k Views
      Ferberto
      Hi all.
      Just setup my first M5 echo! The product seems great so far, I tried the factory BT firmware and it works fine.
      I want to test the Recoder&Replay example, but an error occurred after pressing the button:
      Init i2s_set_pin
      E (2137) I2S: i2s_check_set_mclk(253): ESP32 only support to set GPIO0/GPIO1/GPIO3 as mclk signal, error GPIO number:2133
      E (2142) I2S: i2s_set_pin(314): mclk config failed
      just after
      err += i2s_set_pin(SPEAKER_I2S_NUMBER, &tx_pin_config);
      where
      #define SPEAKER_I2S_NUMBER I2S_NUM_0
      I searched for some solution but I didn't find a good solution.
      Using Visual Studio code, this is the platformio.ini
      [env:esp32dev]
      platform = espressif32
      board = esp32dev
      framework = arduino
      monitor_speed = 115200
      upload_speed = 115200
      lib_deps =
        m5stack/M5Atom @ ^0.0.9
        fastled/FastLED @ ^3.5.0
      Thanks in advance!
      Ferb
        Hello @Ferberto
        I guess you've ran into this issue discussed here.
          Ferberto
          Fantastic, it works!
          Don't know why I wasn't able to find it first.
          Thanks!
