    COM.LTE (SIM7600G) HTTPINIT error
    Modules
    13.3k
    • V
      Veto6017
      Using the AT+HTTPINIT command returns ERROR but I don't know why. The same code worked without problems when I had a 4G connection but now with 3G it doesn't work. Please see the log below:
      Module Reset, please wait
      RDY
      +CPIN: READY
      SMS DONE
      PB DONE
      AT+CPIN?
      +CPIN: READY
      OK
      AT+CSQ
      +CSQ: 20,99
      OK
      AT+CGREG?
      +CGREG: 0,5
      OK
      AT+COPS?
      +COPS: 0,0,"Swisscom Things Mobile",2
      OK
      AT+HTTPINIT
      ERROR
        Hello @Veto6017
        did you check if the SIM7600G has received an IP address using AT+CGPADDR?
        also did you try to issue an AT+HTTPTERM command, maybe HTTP was already initialised?
        • V
          Veto6017
          Hi Felix,
          AT+CGPADDR
          +CGPADDR: 1,0.0.0.0
          OK
          AT+HTTPTERM
          ERROR
          Thanks,
          Roger
            Hello @Veto6017
            ok, so for whatever reason the SIM7600G did not receive an IP address. That is probably the reason HTTP init fails.
            Have you set the APN? Maybe the 3G APN is different from the 4G APN?
            • V
              Veto6017
              Hi Felix,
              I'm using a SIM card from thingsmobile and as far as I understand the APN should always be the same. I've just contacted the thingsmobile support and they did a SIM reset. Sadly I'm now always getting a 4G connection and everything works fine.
              I've tried with AT+CNMP=48 to disable LTE connections to further debug but the setting is reset after AT+CRESET and also after a power reset. Although the manuals states: The set value will retain after module reset. I'm able to execute AT+HTTPINIT after changing preferred mode selection but I want to try it after a reset.
              Do you have an idea how I can force the SIM7600 to connect using 3G?
              Please also see the logs below.
              Thanks, Roger
              Changing APN without success
              AT+CGDCONT=1,"IP","TM"
              OK
              AT+CGPADDR
              +CGPADDR: 1,0.0.0.0
              OK
              AT+CGDCONT=?
              +CGDCONT: (1-24),"IP",,,(0-2),(0-4),(0-1),(0-1)
              +CGDCONT: (1-24),"PPP",,,(0-2),(0-4),(0-1),(0-1)
              +CGDCONT: (1-24),"IPV6",,,(0-2),(0-4),(0-1),(0-1)
              +CGDCONT: (1-24),"IPV4V6",,,(0-2),(0-4),(0-1),(0-1)
              When I have a 4G connection it works
              AT+CGPADDR
              +CGPADDR: 1,10.118.92.113
              OK
              AT+COPS?
              +COPS: 0,0,"Swisscom Things Mobile",7
              OK
              AT+HTTPINIT
              OK
              Changing Preferred mode selection
              AT+CNMP?
              +CNMP: 2
              OK
              AT+CNMP=48
              OK
              AT+CNMP?
              +CNMP: 48
              OK
              AT+COPS?
              OK
              AT+HTTPINIT
              OK
              • V
                Veto6017
                When I use AT+CNMP=48 to disable LTE connections and then check the current IP address using AT+CGPADDR shows no IP (0.0.0.0) but calling AT+HTTPINIT works without an error and after this command I've got a valid IP (see the log below). I will check the device in the field again on the end of this week.
                AT+COPS?
                OK
                AT+CGPADDR
                +CGPADDR: 1,10.118.68.169
                OK
                AT+CNMP=48
                OK
                AT+CGPADDR
                +CGPADDR: 1,0.0.0.0
                OK
                AT+CGPADDR
                +CGPADDR: 1,0.0.0.0
                OK
                AT+COPS?
                OK
                AT+CGPADDR
                +CGPADDR: 1,0.0.0.0
                OK
                AT+HTTPINIT
                OK
                AT+CGPADDR
                +CGPADDR: 1,10.109.3.47
                OK
                  Hello @Veto6017
                  thank you for reporting back - this is quite interesting.
                  I used AT+COPS=1,2,"22802",2 to manually select UTRAN (2) instead of EUTRAN (7).
                  Note: "22802" is provider Sunrise in Switzerland.
                  BTW: AT+COPS=0 gets you back to automatic selection.
