    help, how to drive LED band & neohex with m5stick
    Units
    neopixel led
    4.8k
    • P
      pracio
      i've connect to a led band with grove connector(the default GPIO32 for m5stick). i tried following code but nothing happend...
      from m5stack import *
      import time
      from machine import Pin
      from neopixel import NeoPixel
      lcd.clear(lcd.WHITE)
      lcd.text(lcd.CENTER, lcd.CENTER, "I'm Phelix", lcd.BLACK)
      pin = Pin(32, Pin.OUT)
      np = NeoPixel(pin, 15)
      for i in range(15):
      np[i] = (255,255,255)
      np.write()
      can someone please help me?
        Hello @pracio
        use RGB LED unit in UIFlow which result in this Python code:
        from m5ui import *
        from uiflow import *
        import unit
        setScreenColor(0x111111)
        neopixel_1 = unit.get(unit.NEOPIXEL, unit.PORTA, 10)
        neopixel_1.setColor(1, 0xff0000)
          The Neohex has 37 RGB LEDS and the headband has 118 RGB LEDs.
          the range should be set to 155 as there are now 155 LEDs connected together.
          They should also be connected as below
          However, this many LED's will cause power issues and you will need to build a power booster cable as shown in this guide.
          https://youtu.be/7MP_eG3U2So
