    M5stack BASIC v2.6 GPIO16 input problem
    Bases
    8.1k
    • K
      kazyam53
      I want to use GPIO16 on M5stack basic v2.6 as digital input but it doesn't work.
      I have tried on the code below but it always return 1.
      ・It's work well on M5 stack gray (default 0, when input 3.3V it return 1).
      ・In case I use GPIO17,25,26, it can also work well.
      ・I have 2 of basic v2.6 but both of them have same issue.
      This is the code I have tested.
      #include "Wire.h"
      #include <M5Stack.h>
      #define DIN 16
        //start serial connection
        M5.Power.begin();
        Wire.begin();
        Serial.begin(9600);
        pinMode(DIN, INPUT_PULLDOWN);
        int sensorVal = digitalRead(DIN);
        Serial.println(sensorVal);
      Do you have any solution or find issue on my code?
      Thank you in advance for your help.
        Hello @kazyam53
        M5Stack basic v2.6 seems to have some kind of pull-up resistor (about 3.3 k) on GPIO16. Not sure why and not sure why only on GPIO16.
        That said, you'll need to change your code to pinMode(DIN, INPUT_PULLUP); and then either leave GPIO16 open (reads 1) or connected to GND (read 0).
        • K
          kazyam53
          Then I need to change design... thank you so much for answer.
            macsbug
            Hello @kazyam53
            M5Stack Basic V2.6
            There is a small clearance between the M-BUS and the metal surface on the back of the Speaker, and some are in contact with each other.
            There is a risk of short circuit of M-BUS (GND, 23,19,18,3,16,21).
              Hello @macsbug
              I've noticed that too. However there is insulation (capton tape) on the back of the speaker in my M5Stack base v2.6.
