    Simple Click Sound
    6 Posts 3 Posters 10.8k Views
      purpledread
      I'm using the LVGL with MicroPython for a project and I'd like to be able to make a click noice when the user interacts with the application's buttons.
      Is there any easy way to do that?
        purpledread @purpledread
        @purpledread
        Should have mentioned I'm running on a M5Core2.
        /Chris
          macsbug
          Hello@purpledread
          I don't use MicroPython, but it works with the Arduino IDE.
          Development environment
          Arduino IDE 1.8.9
          LVGL 8.1.0
          M5Stack Basic , Gray , Fire
          Touch and button operation:
          Core2 is used with Touch (x, y).
          M5Stack is used by setting A, B, C Button with x, y.
          Output sound from Button:
          Use M5.Speaker.beep or M5.Speaker.tone.
          Set lv_conf.h for LVGL8 :
          // Set lv_conf.h for LVGL8 : lvgl_8.1.0 / src / lv_conf.h
          // #define LV_TICK_CUSTOM 1 : LVGL lv_conf.h setup
          // #define LV_COLOR_DEPTH 16 : LVGL lv_conf.h setup
          // #define LV_COLOR_16_SWAP 0 : color
          Arduino IDE example :
          // Initialize the (dummy) input device driver/
          void init_m5_button(){
          static lv_indev_drv_t indev_drv;
          lv_indev_drv_init(&indev_drv);
          indev_drv.type = LV_INDEV_TYPE_POINTER;
          indev_drv.read_cb = M5_btn;
          lv_indev_drv_register(&indev_drv);
          // https://github.com/m5stack/m5-docs/blob/master/docs/ja/api/speaker.md
          void M5_btn(lv_indev_drv_tindev_driver,lv_indev_data_tdata){
          int mx, my;
          // A Button : Leftward ----------------------------------------------
          if (M5.BtnA.wasPressed()){ // center position
          mx = 320/2 -100; my = 240/2;
          data->point.x = mx; data->point.y = my;
          data->state = LV_INDEV_STATE_PR;
          M5.Speaker.setVolume(2); // 0, 1 to 8
          M5.Speaker.beep(); delay(100); // beep 100msec
          M5.update(); return;
          // B Button : Rightward ---------------------------------------------
          if (M5.BtnB.wasPressed()){
          mx = 320/2; my = 240/2;
          M5.Speaker.setVolume(1); // 0, 1 to 10
          M5.Speaker.tone(1000, 250); // 1KHz , 250msec
          // C Button : Auto / Manual Display ---------------------------------
          if (M5.BtnC.wasPressed()){
          mx = 320/2 + 100; my = 240/2;
          M5.Speaker.tone(440, 100); delay(100);
          M5.Speaker.mute(); delay(100);
          // No button operation ----------------------------------------------
          data->state = LV_INDEV_STATE_REL; M5.update(); return;
          Use btn Exsample from LVGL 8.1.0.
          // lvgl(8.1.0) / examples / widgets / btn /
          // lv_example_btn_1.c , lv_example_btn_2.c , lv_example_btn_3.c
          // lv_example_btn_1.py
          lv_example_btn_1(); // From the btn demo of LVGL 8.1.0
          lv_example_btn_2(); // From the btn demo of LVGL 8.1.0
          lv_example_btn_3(); // From the btn demo of LVGL 8.1.0
          reference : Core 2 touch
          Void my_touchpad_read(lv_indev_drv_t * indev_driver, lv_indev_data_t * data){
          TouchPoint_t pos = M5.Touch.getPressPoint();
          bool touched = ( pos.x == -1 ) ? false : true;
          if(!touched) {
          } else {
          /Set the coordinates/
          data->point.x = pos.x;
          data->point.y = pos.y;
          return;
            purpledread @macsbug
            @macsbug
            I really appreciate the response, but I'm running with an image that just has lvgl and micropython and not the M5 classes.
            Looking for how to play a sound with the standard esp32 hardware support on the device.
            /Chris
              Hello @purpledread
              not a click sound, but at least a tone on M5Core2.
                purpledread @felmue
                Thanks. Any kind of sound would be great.
                My machine module doesn't have the I2S used in this example.
                /Chris
