    Timer X Camera AWS s3 settup
    General
    5.0k
    • A
      Anarchist_Wolf
      Hello I just bought a Timer X Camera and set up a AWS s3 bucket. Whenever i burn the firmware onto the camera after going through the steps nothing happens. When i check the serial port it shows that the camera is connecting to the WIFI but no images are being sent to the bucket. (And the serial is going to fast i cant really tell where it hangs).
      If anyone had any comments on if it still works or the bucket has to be set up a certain way id much appreciate it.
      Thanks,
      W
      • I
        isamalatby
        The same thing happened to me, I emailed the support team about this problem and they said there is a bug in the example and they will try to fix it soon, nothing happened so far, appreciate if anyone can help
        • I
          isamalatby
          Hello again
          The solution in the link below
          https://qiita.com/hayate_h/items/8d157f657924d51e5d62
          it's chines website, try to use google translation to change the language and it works with me finally
            M5User-60283 @isamalatby
            @isamalatby What you need is likely to prefix "AWS4" to your secret access key - "AWS4<SECRET ASCCESS KEY>". Additionally, your url must be of the format "<API URL>/<BUCKET NAME>".
            https://github.com/m5stack/M5_Camera_Examples/blob/main/idf/AWS-S3-PUT/main/AWS-S3-PUT.c#L59
            Good luck.
