    WIP ACSSR Guide
    PROJECTS
    4.6k
      I can't get RS485/Modbus working and so here is the Work in Progress ACSSR Guide.
      https://www.hackster.io/AJB2K3/get-started-with-the-m5stack-acssr-cf960b
        Hello @ajb2k3
        for your excellent ACSSR guide you'll find below the UIFlow Modbus blocks to switch the ACSSR on / off (together with the RGB LED) using an M5Stack Basic.
        Two things to note which were not obvious to me:
        • Baudrate needs to be 115200 (anything lower only resets the ACSSR)
        • to turn the ACSSR on the value needs to be 0xFF00 (See here)
        Button functions:
        • Button A: relay on / LED red
        • Button B: relay off / LED green
        • Button C: read version
        and the corresponding Python code:
        from m5stack import *
        from m5ui import *
        from uiflow import *
        from modbus.master.uModBusSerial import uModBusSerial
        setScreenColor(0x222222)
        label0 = M5TextBox(54, 58, "label0", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        label1 = M5TextBox(54, 100, "label1", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        label2 = M5TextBox(50, 140, "label2", lcd.FONT_Default, 0xFFFFFF, rotate=0)
        def buttonA_wasPressed():
          # global params
          label0.setText(str(modbus.write_single_coil(4, 0, 0xFF00)))
          label1.setText(str(modbus.write_single_register(4, 0, 0xF800, True)))
          pass
        btnA.wasPressed(buttonA_wasPressed)
        def buttonC_wasPressed():
          # global params
          label2.setText(str(modbus.read_holding_registers(4, 1, 1, True)))
          pass
        btnC.wasPressed(buttonC_wasPressed)
        def buttonB_wasPressed():
          # global params
          label0.setText(str(modbus.write_single_coil(4, 0, 0x00)))
          label1.setText(str(modbus.write_single_register(4, 0, 0x07E0, True)))
          pass
        btnB.wasPressed(buttonB_wasPressed)
        modbus = uModBusSerial(1, tx=17, rx=16, baudrate=115200, data_bits=8, stop_bits=1, parity=None, ctrl_pin=None)
          ajb2k3 @felmue
          @felmue said in WIP ACSSR Guide:
          Hello @ajb2k3
          Button functions:
          from m5ui import *
            # global params
            pass
            # global params
            pass
            # global params
            pass
          Thanks but can't get it to work on a core2 using the RS485 unit
            Hello @ajb2k3
            I've just checked. Above blocks work for me with an M5Core2 as well. Instead of TX=17 / RX=16 I use TX=14 / RX=13. That said I do not have the RS485 unit so I am using the little RS485 board (which came with the LAN module) albeit outside the LAN module connected via a BUS module.
            The ACSSR is powered from an external 12 V power supply. The little RS485 board is powered with 5 V from the M5Core2. There are only two wires between the ACSSR and the little RS485 board: A <-> A and B <-> B. I also added an 120 Ohm resistor between A and B of the little RS485 board. The ACSSR already has that resistor in place internally.
