    Core2 with W5500 and RS485 (ModbusMaster) with more then 2 slaves
    1 Posts 1 Posters 1.9k Views
      Highlandy
      Hello, everyone
      I am trying to read data from 4 slaves with M5Core via Modbus RTU. Unfortunately, only communication with 2 slaves works. As soon as a third slave comes along, the connection breaks down with errorcode "E2" (Timeout).
      Here the code:
      #include <M5Stack.h>
      #include <ModbusMaster.h>
      ModbusMaster node1,node2,node3,node4;
      uint8_t result1,result2,result3,result4;
      TFT_eSprite img = TFT_eSprite(&M5.Lcd);
      int i;
      M5.begin(true, false, true, false); // Init M5Core.
      M5.Power.begin(); // Init Power module.
      img.setColorDepth(8); // Set color depth.
      img.setTextSize(2);
      img.createSprite(320, 240); //Create a 320x240 canvas.
      Serial.begin(115200);
      Serial1.begin(9600,SERIAL_8N1,16,17);
      node1.begin(1, Serial1);
      node2.begin(2 , Serial1);
      node3.begin(3, Serial1);
      node4.begin(4, Serial1);
      Check1();
      delay(1000);
      Check2();
      delay(1000);
      Check3();
      delay(1000);
      Check4();
      delay(1000);
      void Check1(){
      i=1;
      // Read 21 register starting at 0
      while ((i>0)&(i<5)) {
      result1 = node1.readInputRegisters(0,21);
      Serial.println(result1, HEX);
      if (result1 == node1.ku8MBSuccess) {
      Serial.print("Id1 ");
      Serial.print(node1.getResponseBuffer(0)/100);
      Serial.print(node1.getResponseBuffer(1)/100);
      Serial.println(node1.getResponseBuffer(2)/100);
      i=0;
      else {
      Serial.print("Error ID1\n");
      delay(250);
      i++;
      void Check2(){
      i=1;
      result2 = node2.readInputRegisters(0,21);
      Serial.println(result2, HEX);
      if (result2 == node2.ku8MBSuccess) {
      Serial.print("Id2 ");
      Serial.print(node2.getResponseBuffer(0)/100);
      Serial.print(node2.getResponseBuffer(1)/100);
      Serial.println(node2.getResponseBuffer(2)/100);
      i=0;
      else {
      Serial.print("Error ID2\n");
      delay(250);
      i++;
      void Check3(){
      result3 = node3.readInputRegisters(0,21);
      Serial.println(result3, HEX);
      if (result3 == node3.ku8MBSuccess) {
      Serial.print("Id3 ");
      Serial.print(node3.getResponseBuffer(0)/100);
      Serial.print(node3.getResponseBuffer(1)/100);
      Serial.println(node3.getResponseBuffer(2)/100);
      else {
      Serial.print("Error ID3\n");
      void Check4(){
      result4 = node4.readInputRegisters(0,21);
      Serial.println(result4, HEX);
      if (result4 == node4.ku8MBSuccess) {
      Serial.print("Id4 ");
      Serial.print(node4.getResponseBuffer(0)/100);
      Serial.print(node4.getResponseBuffer(1)/100);
      Serial.println(node4.getResponseBuffer(2)/100);
      else {
      Serial.print("Error ID4\n");
