    2022 M5 Stamp Pico and Waveshare epaper Arduino Library?
    2 Posts 2 Posters 2.8k Views
      hausofpayne
      Re: Connecting Epaper display to m5stack core or other models ? (Waveshare)
      Site says previous topic is old so I started a new one on its suggestion.
      Hi there. I know there's an M5Paper product.
      But I'd like to connect a Waveshare 1.54" bw epaper display to an M5Stamp Pico board.
      Are there any Arduino libraries available to do this?what are they called?
      What are the M5 pins that I connect the DI, SCK, CS, Dc, BUSY and RESET pins.
      Thanks for your suggestions/recommendations.
        Hello @hausofpayne
        ESP32 allows to assign almost any functionality (SPI, I2C, etc.) to almost any GPIOs.
        Using the example GxEPD2_WS_ESP32_Driver.ino from the GxEPD2 library with the following GPIO setup worked for me. (Note: I used a Waveshare 2.9" ePaper for my test.)
        • DI <--> 26
        • SCK <--> 18
        • CS <--> 21
        • DC <--> 22
        • BUSY <--> 32
        • RESET <--> 33
        On line 118 of the example you set the GPIOs for CS, DC, RST and BUSY:
        GxEPD2_DISPLAY_CLASS<GxEPD2_DRIVER_CLASS, MAX_HEIGHT(GxEPD2_DRIVER_CLASS)> display(GxEPD2_DRIVER_CLASS(/*CS=*/ 21, /*DC=*/ 22, /*RST=*/ 33, /*BUSY=*/ 32));
        On line 150 of the example you set the GPIOs for SPI:
          SPI.begin(18, 36, 26, 21); // map and init SPI pins SCK(18), MISO(36), MOSI(26), SS(21)
