    [Solved]Unable to turn off when USB is Connected
    Cores
    11.9k
    • yuriklebY
      yurikleb
      I'm unable to turn off the m5stack when a USB cable is connected.
      I want to reduce the charging time so it would be great to be able to keep the device off when connected to a charger. Is there no such option?
      • RopR
        Rop
        If you are using software that allows you to do so, you can turn off from software. In your own code, simply put m5.powerOFF();.
        yuriklebY 1 Reply Last reply Reply Quote 0
        • yuriklebY
          yurikleb @Rop
          @rop cool thanks!
          Do you the python version of that line?
          Thanks!
          • m5-docsM
            m5-docs
            Hello
            You can put M5 to deep sleep using machine.deepsleep()
            similar to this.
            https://qiita.com/taka-murakami/items/0d2b4734b08516135d74
            M5Stack documentation URL
            https://docs.m5stack.com
