    Core 2 Factory Test Progress Bar
    Core 2
    3.8k
    • G
      greenhorn
      Hi All,
      Just got my Core 2 and started playing with the factory demo that came out of the box. I like the homage to Evangelion in the layout on the top right. ;)
      I wanted to replicate the diagonal progress bar on the top of the timer for my own project.
      How is this done? I checked the source code in the link below but it is quite condensed and hard to find since there seems to be 3 sprites/images doing something similar.
      https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Core/M5Core2/Arduino/Core2_Factory_test
      Could you please point me in the right direction?
      Thanks,
        Hello @greenhorn
        it's part of the clockFlush() function. Six images loaded sequentially over and over.
            sytState.clockCount ++;
            sytState.clockCount %= 6;
            DisClockbuff.drawColorBitmap(0,0,164,17,
                                    rectptrBuff[sytState.clockCount],
                                    0xff9c00,
                                    0x000000);
        • G
          greenhorn
          Thanks, I'll check it out and give it a try.
          • AsmodevA
            Asmodev
            My core2 makes a noise when i install the factory software using arduino or the built in burner, also it does nothing, i can’t seem to get it back onto the device, what gives? I’ve connected to serial port, burned the test and then all i hear is a low pitch noise… Anyone know about this?
