M5 Stack unable to subscribe and recieve new messages
Hello everyone, I am trying to print new messages on my m5 stick c plus, through hive mq. I am able to publish, but not able to subscribe. Not sure what is the issue here, please advise! Thank you in advance!
Here is my code:
from m5stack import * from m5ui import * from uiflow import * import time setScreenColor(0x111111) PASSW = None CLIENTID = None USER = None HOST = None label0 = M5TextBox(47, 49, "label0", lcd.FONT_Default, 0xFFFFFF, rotate=0) label1 = M5TextBox(47, 176, "label0", lcd.FONT_Default, 0xFFFFFF, rotate=0) PASSW = 'password' CLIENTID = 'm5stack' USER = 'user' HOST = '07ecd30c.s1.eu.hivemq.cloud' from m5mqtt import M5mqtt m5mqtt = M5mqtt(CLIENTID,HOST,8883,USER,PASSW,300,ssl=True,ssl_params={'server_hostname':HOST}) m5mqtt.start() label0.setText('Hello M5') a = None def callback(topic_data): a = topic_data label0.setText(str(a)) pass while True: m5mqtt.subscribe(str('topic/1'), callback)My StickCPlus is currently v1.9.8-plus
Hello @sleepyfatcat
any particular reason you subscribe in an infinite while loop? Last time I tried mqtt I called
m5mqtt.subscribe()only once and just before callingm5mqtt.start().Thanks
Felix -
what do you mean by "Not able to subscribe" ?
Does it not connect or does it not return data?
Does the data turn up in HiveMQ?This looks like Micropython but the functions look strange, you have SSL set to true but no keys and certificates set.
