m5stack core turns itself off
I am running my program from the APP mode. After a couple of minutes the m5stack turns itself off. the only way to wake it up is by attaching it to usb c. Is there a standard deep sleep mode that gets activated?
@asshutossh Check for memory issues, Kernal panics and or Guru meditation errors using a terminal program.
There are only 2 causes for this.
the first is the battery not charged fully or The memory is getting filled and causing a kernal panic resulting it CPU shutoff or reset.
