    M5 tough remove touch buttons
    Scheduled Pinned Locked Moved Lessons and Guides
    7 Posts 4 Posters 12.1k Views
      HansDia95
      Hello
      I have tried everything when it comes to removing/hiding/deactivating a button on the touch screen on an M5 tough, searching Google in and out. When I use .fillScreen(), it fills the screen but I can still "click" the button when I touch the screen where it was and then it appears again.
      Hoping for an answer to this small question.
      Thanks a lot! :D
        Hello @HansDia95
        using UIFlow firmware 1.9.8 on my M5Tough I can simply hide a button and after that it no longer is touchable until I make it show again.
        Have you tried Set touch_button_X hide block?
        Care to share your UIFlow code?
          HansDia95
          Hi again I'm using Arduino IDE btw :)
          Thanks again :)
            Hello @HansDia95
            I assumed you are using UIFlow since you've posted under SOFTWARE / UIFlow ...
            Anyways, with Arduino there seems to be an issue with hiding (static) buttons. However when I use dynamic buttons it seems to work. Here is a function creating / showing or hiding / deleting a button.
            Button *b3 = nullptr;
            void showHideButton3(bool show)
              if(show == true)
                if(b3 != nullptr) return;
                Serial.println("*** show");
                b3 = new Button(220, 200, 80, 40, false, "C", off_clrs, on_clrs, MC_DATUM);
                b3->addHandler(eventDisplay, E_ALL);
              else
                if(b3 == nullptr) return;
                Serial.println("*** hide");
                b3->delHandlers();
                b3->hide(BLACK);
                delete(b3);
                b3 = nullptr;
            BTW: I was using above in the context of the M5Tough Touch example.
              SkyNorth
              Look in
              https://github.com/m5stack/M5Tough/blob/master/src/utility/M5Button.h
              It explains the touch button usage.
              -Brent
                HansDia95 @SkyNorth
                @skynorth Thanks A lot!!
                it was button.hide(), but I had to fill the screen after.
                Thanks!!! :)
                  CharlieTango @HansDia95
                  @hansdia95 I am running into problems with using button.hide() Can you please provide an example of your usecase? Perhaps I just have a syntax error. I can not find much informaiton on this other than the writeup on github (that provides little informaiotn on this)
